not optimum mode recommended mode 1360x768 60hz
nachocaro
Commendable
Feb 7, 2017
hi
yesterday I installed a gtx 1050ti 4g, i have a vga monitor so I bought an adapter.
It was all going well until I decided to change the resolution of the monitor from the recommended (1360x768) to 1920x1080, just to see what happen, my monitor cant deal with 1080p. Obviously it didnt look good, so I changed it again to the recommended mode 1360x768. But for some reason the not optimum mode showed up. I dont know what to do
thanks
No i mean:
1360x768 and 1366x768 are two different resolutions, and one may be the optimum while the other isnt:
yes i know, i put it bad in the description it has always been 1360x768 the recommended one, now i change the description
i still have the problem
thanks for reply
I found this solution
1. Make sure you choosed best solution in windows setting
2. Right Click on desktop then click NVIDIA Control Panel
3. On NVIDIA Control panel in left tab, click on Change Resolution, The resolution list choose lower resolution, click apply. After it, change back to 1366x768 (same as windows resolution) then apply again
Done
