Question Not receiving display with DP Cable from RTX 2070 to 144hz Display
Jul 1, 2019
38
I recently got myself an RTX 2070 GPU. I aleredy had a 240hz Zowie XL2546 Monitor to be it's main source, but I have another 144hz Monitor which I usually would use as my secondary monitor [Dual-Monitor-Setup]. Before aquiring the new GPU, I had GTX 970 which I then used a DVI cable from that to the 144hz Monitor to get the refresh rates.
However, on this new GPU, it's not detecting any signals from the 144hz Monitor anymore. I tried every DP Input on my GPU (It has 3), and nothing happens. What also was weird was that I tried the same with my 240hz Monitor (using it's DP Cable) but nothing happened then either.
DP Cable = DisplayPort Cable
My Setup:
Intel Core i7 9700k
MSI RTX 2070 Tri Frozr
Corsair Vengeance LPX DDR 3200Mhz 2x8GB
MSI MPG Z390 GAMING PRO CARBON
