NOT SOLVED!]DiRT 3 Not starting, at all. Tried everything, PLEASE help
taltool24198
249
Hey guys. Basically, I have played some Dirt 3 for around two weeks now. Havnt changed a thing, but for some reason, dirt 3 is just not launching anymore. At all.
I press it, it does the loading icon on the mouse, and nothing.
Running as admin.
Running as windows XP, vista, 7, 95, basically everything.
Installed on 3 different drives
Reinstalled on 3 different drives.
Reinstalled .NET 4
Reinstalled C++.
Tried searching online but nothing helps.
you found infections when you did a scan and the game no longer works. that means it did find something that was used by dirt 3. it may not be part of the main install but it may well be a part of windows that dirt 3 depends on. you need to repair windows and check your updates are correct.
run sfc/scannow with admin privs via the CMD prompt.
If someone here actually had a valid answer, I'm sure they would give it to you. This place is very generous with help.
Dirt3 has been riddled with problems. It's a fantastically fun game, but I have pulled my hair out getting it to run correctly on my system....everything from stuttering issues to corrupted profiles (thanks to GFWL) causing me to lose almost 100 races. Because your savegame is linked to GFWL, you can't back it up or replace it. Corrupted save? Start ALL OVER. Horrible system to implement on a game like this.
GRID lets you backup and restore your profile the proper way....locally. This has saved me more than once. Thank you Codemasters.
I have the STEAM version, FWIW.
I assume (since you have the DVD version) that you have updated it with the official patches? Perhaps you should try launching it before installing any patches.
I can't physically launch it.
I press the icon and NOTHING happens. At all.
I haven´t got any problem running the game, or save them.
What do you mean by "Thank you Codemasters"? Isn´t Dirt3 from Codemasters too?
done a virus scan?
if you have a pirated version, and i have brought gta4 that looked original but wasnt, played for a while ran a virus scan and it deleted budda.dll or similar, and had drunk cam after, weeks of trouble shooting and it turned out i had brought a dodge copy, so had to buy again,
does it look 100%? mine had had the label burned on with lightscribe or something, it wasnt printed i know that
Yes, Ive done a virus scan. It didnt delete anything related to dirt 3.
Bought it from amazon, so 110% legit.
Dont know what to do now. I dont get any error of somethibg missing, it just basically ignores me. It does a sign of loading a disc, then a normal loading, then it STAHPS AND DOES NOTHING 🙁🙁🙁
Doing a sfc/scannow run right now, will report ones its done.
"Windows Resource Protection found corrupt files but was unable to fix some of them.
Details are included in the CBS.Log ...."
The list is SUPER long... I can't paste it here, it will just kill the forum and make like 18 pages.
Hi :)
If the list is that long its TOTAL REINSTALL of Windows time... 🙁 (and I mean FORMAT and reload)
All the best Brett :)
