Not sure about which system will be best for gaming
Witch system is best for gaming ?
  • System 1
    Votes: 4 57.1%
  • System 2
    Votes: 3 42.9%
  • Total voters
    7
ben BOys
58
right system 1 is this
System 1
AMD PHENOM™ II X4 940 (3.0GHz) 8MB CACHE (Socket AM2+)
4GB CORSAIR DOMINATOR 1066MHz - LIFETIME WARRANTY (2x2GB)
ASUS® M3A79-T DELUXE: AM2+, DUAL DDR II, S-ATA II, 2 PCI
8 x USB 2.0 PORTS (6 REAR + 2 FRONT) AS STANDARD
640GB SERIAL ATA II HARD DRIVE WITH 16MB CACHE (7,200rpm)
22x DUAL LAYER LIGHTSCRIBE DVD WRITER ±R/±RW/RAM
1024MB RADEON HD 4870 PCI Express + DVI
Antec Nine Hundred Black Gaming Case with Side Panel Window
700W Quiet Quad Rail PSU + 120mm Case Fan (£78)
ASUS TRITON 81 PURE COPPER BASE ULTRA COOLER (£45)
24 Inch Wide TFT Silver/Black 1920 x1200 8MS D-Sub, DVI (£175)
System 2
Intel® Core™i7 Processor i7-920 (4 X 2.66GHz) 4.8GTs/8MB Cache
6GB CORSAIR XMS3 1333MHz - LIFETIME WARRANTY! (3x2GB)
ASUS® P6T DELUXE: DDR3, SATAII, 2 x PCI-e x16, 2 PCI, 1 x PCI-e x1
320GB SERIAL ATA II HARD DRIVE WITH 8MB CACHE (7,200rpm)
512MB RADEON HD 4850 PCI Express + DVI
witch ones best for gaming?
Pretty close to being equal. Both would be "good enough".
For example the AMD system would probably be better in Crysis and the Intel system would probably be better in Far Cry2.
Raidur
2,365
System #1 for sure. Core i7 won't make much of a difference in games over the AMD 940. Especially not enough to make 2 4850s outperform 2 4870s. Plus you'd be more gaming future proof with the 2 4870s.
Don't get me wrong, Core i7 performs extremely well, as do 2 4850s. But 2 4870s would smash (well maybe not SMASH, but you catch my drift) Core i7 with 2 4850s, especially with the 1GBx2 Vram w/ your 1920x1200 resolution.
At least that's what I think.
G
Guest
Guest
what he said. if you're mostly gaming, more gpu is your friend.
chad_69
33
Core I7 920 can be overclocked to 4.0ghz...a great overclocker. I7 is an awsome gaming CPU over the AMD. Just google it and check the stats. Even thought the AMD system specs show a better graphics card...the core I-7 will still have faster frames per second in the majority of the latest games.
