[SOLVED] Not sure if gpu will fit?
Pshaw. Really?
The case is 200mm wide. That's plenty of space for any gpu made, they are all pretty standard in that respect, some differences due to shrouds.
The gpu is 142mm wide.
But that's not the issue. Outside diameter means nothing. Gpu clearance is everything as no matter which case length outside, there's front covers, intake fans, hdd trays etc which can limit gpu clearance on the inside.
Only 2 ways to see if it'll fit. Either physically measure the distance from the pcie slot towards the front, checking to see if hdd cages are removable or not etc, or look up the case model online which almost always includes gpu clearance with/without hdd cage.
Pshaw. Really?
