Hello, I recently ordered my first customized tower from Cyberpowerpc- and being a noob and quite new to these sorts of things; I really didn't take into consideration and know that cpu's and the system requires adequate cooling so things do not go haywire. I do not plan on overclocking the system, or render any videos. I am just using it to play games that I enjoy such as: League of Legends, Fallout, Steam Games, and just for recreational gaming.The specifications for my system are:
CAS: CyberPowerPC X-Nova Mid-Tower Gaming Case w/ USB 3.0, Side-Panel Window [-22]
CASUPGRADE: None
COOLANT: Standard Coolant
VIDEO CARD: NVIDIA GTX 970 4GB
CPU: Intel® Core™ i7-4790K 4.0 GHz 8MB Intel Smart Cache LGA1150 (All Venom OC Certified) [+110]
CS_FAN: Default case fans
FAN: Asetek 570LXL 240mm Liquid CPU Cooling System w/ Copper Cold Plate [+30] (2 x Standard 120MM Fans)
HDD: 1TB SATA-III 6.0Gb/s 32MB Cache 7200RPM HDD (Sandisk 128GB SSD + Single Drive)
MEMORY: 16GB (8GBx2) DDR3/1600MHz Dual Channel Memory (Corsair or Major Brand)
MOTHERBOARD: MSI Z97S SLI Krait Edition ATX w/ GIGABit LAN, 2 PCIe x16, 3 PCIe x1, 1x M.2, 6x SATA 6GB/s (All Venom OC Certified)
OS: Windows 8.1
POWERSUPPLY: 600 Watts - Standard 80 Plus Certified Power Supply - SLI/CrossFireX Ready
I opted for the 240mm liquid cooling, and noticed that there were two default case fans. I was wondering if this is enough? Or should I get extra fans? Also, is it possible to install extra fans even if this was a prebuild? I am just really worried, since I spent quite a bit of money on my first system, and I do not want any problems.
CASUPGRADE: None
OS: Windows 8.1
