Not sure if i should buy these parts, because of any problems that could happen and any improvements under the $1500 budget
Saxicolous
19
This is the custom build of my pc below, please tell me if there are any problem with my custom build pc that i should change or improve.(Changed the motherboard and power supply)
CPU
Intel Core i5-4690K 3.5GHz Quad-Core Processor
$239.99
CPU Cooler
Cooler Master RR-T4-18PK-R1 70.0 CFM Rifle Bearing CPU Cooler
$14.99
Thermal Compound
Arctic Silver 5 High-Density Polysynthetic Silver 12g Thermal Paste
$16.99
Motherboard
Gigabyte GA-Z97X-Gaming 3
$128.99
Memory
Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-2400 Memory
$169.99
Storage
Kingston HyperX 3K 120GB 2.5" Solid State Drive
$84.14
Western Digital BLACK SERIES 1TB 3.5" 7200RPM Internal Hard Drive
$77.79
Video Card
MSI GeForce GTX 780 3GB TWIN FROZR Video Card
$474.99
Case
BitFenix Comrade ATX Mid Tower Case
$39.99
Power Supply
Raidmax Cobra 600W 80+ Bronze Certified ATX Power Supply
$59.99
Optical Drive
Samsung SH-224DB/RSBS DVD/CD Writer
$14.99
Case Fan
BitFenix Spectre Pro LED 56.2 CFM 120mm Fan
More for the TIM than the cooler ? A Hyper 212 will cost ya $30 with the TIM
You have plenty of room left in ya budget.
Corsair 500R- $80
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139010
XFX Core Edition 850 - $95 The 850 watts makes you ready for a 2nd 780 in the future in SLI..... You could drop to the 650 watter if sure you will never use more than at 1 card but what are yta saving..... $15 - 20 ?
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207011
Your MoBo / CPU - $385
Your Storage - $162
Your GFX Card - $475
Your Memory - $170 Could go slower and smaller but hesitate to recommend that since you didn't specify what ya going to do with it. To my mind, and extra $20 for 2400 over 1600 is well...
I honestly spent less and get much better performance. I am not sure what is eating up your budget. What I do see - you don't need 16 GB for gaming. 2 x 4 GB RAM would do you just fine. You probably need a better cooler for that Haswell CPU. That will barely run and rules out any overclocking you want to do for added performance.
I'd drop down to 8gb ram, change to a hyper evo cpu cooler, get a better psu and get the PowerColor R9 290 TurboDuo combo, $399 gets you 780 performance AND it comes with a 250GB Samsung EVO SSD.
Nice one, that should be great. Now, what PSU would you get?
Corsair 500R- $80
Your Storage - $162
Your Memory - $170 Could go slower and smaller but hesitate to recommend that since you didn't specify what ya going to do with it. To my mind, and extra $20 for 2400 over 1600 is well worth it. Fast memory comes in very handy for CAD, video editing, large spreadsheets, databases, CS6 etc but it also has an impact on gaming.
The oft quoted wisdom that it's "not worth the cost" comes from a day when 2400 was $100 more than 1600. But at $20 ?? While the increase is modest (0 - 5%) on average fps in most games, it does however have a bigger impact on minimum frame rates and more so in SLI/CF. In some games, the increase from 1600 to 2400 is as high as 11%. ....
So if you will be using any of those types of programs, or use any of the affected games (STALKER, F1, etc) , is that worth a 1% increase in system cost ? To my view, "in a heartbeat".
CPU Cooler - Phanteks PH-TC14-PE - $65
http://www.newegg.com/Product/Product.aspx?Item=N82E16835709011
Total $1432.
My two cents:
1) CPU cooler: Noctua NH-U12S
Yes, it's more money but worth it. It's dead silent in idle and barely audible under heavy load. The Hyper 212 EVO is okay but it is noisier as I could hear the fan under light load and you'll want to overclock that CPU.
The Noctua also includes the paste needed.
2) 8GB 1600MHz CAS9 (2x4GB)
I agree with this unless you are doing video editing, using VM's or some other demanding task that absolutely needs more than 8GB. If gaming does in few years by more memory.
3) *POWER SUPPLY*
WARNING: You want to get a Power Supply that specifies it supports the "C6/C7 Haswell (4th gen) power state". If you don't get such a power supply your system can CRASH when exiting the low power state. You can Google that.
