Question Not sure what is wrong with my system...
Jan 4, 2020
5
So my pc runs fine for majority of the time but some days it just gets in a 'mood' and crashes 4/5 times in a day. BSOD memory management most of the time with a variety of others occuring randomly. I've replaced my MB and RAM and the errors still continue. There are no errors I can find using memtest. Any assistance would be greatly appreciated.
Vic 40
Polypheme
Herald
To solve problems we need a partslist,
download hwinfo,
install and open it=click run,
close the top window which is the system summary,
in the main window at the left top click "save report",
at the bottom of the next window check "Summary for Clipboard",
after that you'll see what's in the pc,
copy by clicking "copy to clipboard" and rightclick+paste in your next respons
or use the pcpartpicker to make a list.
Need info about psu so maker+model+wattage.
Jan 4, 2020
5
Thank you for the instructions, I have included below: TIA
Computer: ASUS All Series
CPU: Intel Core i7-4790 (Haswell-DT Refresh, C0)
3600 MHz (36.00x100.0) @ 3897 MHz (39.00x99.9)
Motherboard: ASUS Z97M-PLUS
BIOS: 2902, 12/04/2015
Chipset: Intel Z97
Memory: 16384 MBytes @ 1066 MHz, 11-13-13-35
- 8192 MB PC12800 DDR3 SDRAM - Corsair CMY16GX3M2A1600C9
Graphics: ASUS STRIX GTX 960 DirectCU II OC
NVIDIA GeForce GTX 960, 4096 MB GDDR5 SDRAM
Drive: WDC WD10EZEX-00BN5A0, 976.8 GB, Serial ATA 6Gb/s @ 6Gb/s
Drive: ST1000DM003-1SB102, 976.8 GB, Serial ATA 6Gb/s @ 6Gb/s
Drive: ADATA SU800NS38, 250.1 GB, Serial ATA 6Gb/s @ 6Gb/s
Sound: Intel 9-series Chipset - High Definition Audio Controller [A0]
Sound: NVIDIA GM206 - High Definition Audio Controller
Network: Intel Ethernet Connection I218-V
OS: Microsoft Windows 10 Professional (x64) Build 18362.535 (1903/May 2019 Update)
PSU: Coolermaster 650W Model: RS-650_AMAA-B!
Vic 40
Polypheme
Herald
Can you enable XMP for the ram, it will make it work at rated speed and timings,where the latter might have an effect.
See your cpu runs at 3.9ghz, did you try and overclock it? or is this just a result of turbo? If tried to just overclock it a little undo and test.
There is also a later bios than you have which improves system stability so do suggest to update.
The psu you have seems decent quality,but have also seen people here that had problems because of it. Just see what the above three things bring (testing one after another),but might need to look at this as well.
Jan 4, 2020
5
Thanks for the assist, I have started implementing the above and will let you know how it goes.
Jan 4, 2020
5
No crashes as of yet after doing BIOS update. But time will tell the true story...
On an unrelated note: what would you upgrade first when looking at my system?
