hey guys, i'm working on my wishlist. first of all, i have a 21" crt monitor. i dont plan using it again! I really want a LCD 24" monitor with my new upcoming rig that i'd be building soon (hopefully). I'm very unsure what to choose and what to go for. I was told that EVGA 512-P3-N841-A3 GeForce 8800GTS (G92) 512MB 256-bit GDDR3 PCI Express card probably wont run very well on a large monitor such as 24". i'm not sure why, they said the resolution is high. i thought greater resolution = better picture. (maybe i was told wrong or i'm wrong. i'm not sure.) with helps would be awsome.
I was looking at this monitor 24" acer 2ms, with high contrast with something like 4000:1 or something with high resolution like 1920x1200 i think. i'm not so sure, because the monitor i've been looking at... newegg got rid of it. I have no clue why! Anyways, any one have comments? can this video card run good on 24" monitor with high MS , high ratio ie 3000:1 and high resolution. IF you need more info about specs. here it is.
c2q q6600 go stepping
ASUS P5K-E/WIFI-AP LGA 775 Intel P35 ATX Intel Motherboard
PC Power & Cooling Silencer 610 EPS12V EPS12V 610W Continuous @ 40°C PSU
G.SKILL 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000) Dual Channel
Any inputs would be great. thanks!
PS: basically what i'm asking, is can i get a 24" and use it just fine with what i have for spec? i really perfer not to get any size less than 24...
