At a guess, I'd say your RAM is starting up at the JEDEC default transfer rate of 1333MT/s, i.e. with a true clock speed of 666MHz. Some documentation and utility programs confuse memory transfer rates (measured in MT/s) with clock speed (measured in MHz).
Double Data Rate (DDR) RAM transfers data on the rising and the falling edges of each clock pulse. At stock speeds, your DDR3 RAM will run at 666MHz clock speed, giving an effective transfer rate of 1333 Mega Transfers per second. For DDR, Transfer rate = 2 x Clock speed.
If your CPU and motherboard are capable of higher XMP overclocks, you might be able increase the memory clock speed to 1066MHz, giving an effective transfer rate of 2133MT/s, i.e. DDR3-2133.
If your CPU and motherboard do not allow transfer rates as high as 2133MT/s, you could try 1866MT/s (933MHz clock) or 1600MT/s (800MHz clock).
There is no absolute 100% cast iron guarantee you will be able to achieve 2133MT/s without some manual tweaking in the BIOS.
Best of luck getting your clock rate up to 1200MHz (2400MT/s) with the four new DIMMs. It's generally easier to overclock two DIMMs because they place a lighter load on the Integrated Memory Controller.
Four DIMMs increase memory bus loading, especially if you don't buy a matched set of 4 DIMMs. Two pairs will never be identical in all respects and can lead to instability at high XMP speeds.
