Not sure what system to get, any help will be highly appreciated...
LNC_GoldenAxe
Hi, I need some help picking out a system so I was thinking of getting this system with an ATI Radeon HD 7570 1gb low profile:
(HP Pro 6300 - Intel 3rd Generation Core i5-3470 3.2GHz quad core CPU, 4GB RAM)
https://www.newegg.com/Product/Product.aspx?Item=9SIA7JW53D7077
http://www.ebay.com/itm/Dell-ATI-Radeon-HD-7570-1GB-GDDR5-Low-Profile-Video-Card-4C5DK-W-DISPLAY-PORT-/322448009171?hash=item4b136627d3:g:VVUAAOSwNRdYAT1h
or
should I get this system AMD system that uses an APU :
(HP Desktop Computer EliteDesk 705 G2 A8-Series APU A8 PRO-8650B (3.2 GHz) 8 GB)
https://www.newegg.com/Product/Product.aspx?Item=N82E16883286051
Which system will be best for gaming, any advice would be appreciated. Thanks!
the second one is probably a better option. adding any kind of graphics cards in these sff prebuit systems can be tricky because you always run the risk of overtaxing your psu. then you try to upgrade the psu and the connectors don't match... sure, the first option is faster, but in the long run you're probably safer to just pick the second one. the 7570 isn't a monster card either, its performance is probably around the same as the integrated gpu in the second one. the first one is faster because of that cpu.
