Not sure what the problem is
Krischico
Hi,
I'm having a bit of an issue with general sluggishness. I'm on my desktop and my mouse skips across the screen without doing anything special. If I load something, it becomes pretty bad (webpages, files, anything really). I've also got a few blue screens on start up, in which I re-seated my ram sticks to fix the problem. Stopped since, but has happened a few times afterwords. I have done a Mem check, came out clean with 20 passes. Started up windows with 1 stick each, same problems. Checked hard drive for bad sectors, came out clean. Checked and dusted off my video card, same problems. Re-installed vid card drivers, same problems. Makes me think its my motherboard but I have no idea what it could be. If this isn't the place to post this, I'm sorry, if someone could point me in the right direction I would be grateful.
Here's my system spec's.
AMD Athlon(tm) II X2 240 Processor
784 Mhz, 2.00GB
Windows XP SP3
Nvidia Geforce 8800 GTS
Biostar TA790GXB3 Motherboard
585W Power Supply
OCZ Gold 2GB (2 x 1GB) DDR3 RAM
Western Digital Caviar Green 500gb SATA
