Question (Not sure whete to post this) rca cambio V2 help
Apr 8, 2021
Hello, im in desperate need of either a full recovery image for the windows 10 rca cambio V2 (this is the v2 version of the tablet, v1 drivers and stuff doesnt work for it, ive tried) or the full driver packages. Im in specific needing audio drivers, is what i mainly care about, but im also i need of the sd card reader drivers, the front camera driver, and a few others. I know this has been asked and answered multiple times on here, but every thread i have read, it either does not work, or (mainly) the links no longer exist. If anyone can help me, itd be highly appreciated. By the way, REINSTALLING USING A REGULAR WINDOWS ISO WILL NOT WORK, the reason for this is because the drivers used for the rca cambio v2 is not included in tge windows 10 isos and stuff, if i install one of them, i basically brick my tablet
I had yesterday the same problem with my RCA CAMBIO Windows 10. I researched what other ppl have done. Nobody had the answer. I was going to reset my tablet, but before I did the following:
1) I checked in CONTROL PANEL, if any device had a conflict. (yes, there was an unknown device). I Uninstalled it.
2) In Ctrl Panel the Bluetooth had many devices, I disable them.
3) I deleted my device in Sound.........it was good and not
4) After deleting my device in sound, I thought that if I checked for new devices the Windows will reinstall any new devices........No! It installed again the device with conflict......
5) What i did is to installed devices in Control Panel -> Device manager -> Install legal SW (software)
6) I installed first driver from Intel Speaker (Even though mine was Realtek as I have seen, but my hubby RCA Cambio had Intel).
7) It didn't function. Then I downloaded the Realtek drivers and installed them through step 5)
8) After that in my Control Panel Audio Devices appeared intel and Realtek devices
9) I didn't get a sound in that moment....But
10) I check the Sound Icon in the left bottom corner of my table, Selected the playback device and there appeared 2 of them. I selected Speakers (Intel SST AudioDevice (WDM)).....AND NOW MY TABLET HAS SOUND.
Hope my experience is of any help for you!
p.s. The problem happened after updating windows 10
https://answers.microsoft.com/en-us...0-update/8e2fd3ce-0362-4aa1-b61c-6c2f594f5673
you might get a faster answer on this forum, its our sister site - https://forums.tomsguide.com/
Id rather nor have to make another account. Also, you apparently didnt read through the actual post, since i stated i have tried multiple of these methods and none of them have worked. The only way to fix this would be to get a full recovery backup image of the device, and copy that over to my device. I tried manually installung drivers, i tried installing both intel and realtek, i tried installing inly realtek, and only intel, i tried searchinf for the particular drivers and have tried multiple other things, which i actually STATED in the post. Im sorry if im incorrect, but it appears that you literally just searched the problem up and took the first link available and pasted it here, correct me if im wrong
