Novabench test results...what do they mean?Help with computer build problems
dairyman3833
I am having some issues with a custum computer build. Had to RMA Mobo and Ram, but still having issues. Tried using CPU-Z, Prime 95, and Novabench(the latest one I used) but really doesn't tell me anything. It's all mumbo jumbo to me. This computer should be running balls out, it's a descent size, but programs keep stalling, some don't even work(Pro Tools, and graphics run laggy. Even surfing internet runs laggy sometimes.
I've got-
Asus M5a97 R2.0 Mobo
AMD-FX 8350
Noctua nd14 cpu fan
16gb Kingston Fury 1600 Ram
1100 PSU-no idea what brand it's not on there
Sapphire Raedeon R9 290x Tri-OC the 01 model # version
Windows Ultra 7 64
Motu 424pcie sound card
WD 500gb Black Caviar HD for operating system
And 4 other HD's for various stuff like storage.
Have a Crucial 512 bx100 SSD I was gonna install for the OS drive but wanted to correct the issues 1st.
I checked some of the driver updates on Device Manager manually, and Windows said all was up to date. But found that these things listed below do not have drivers, and not sure if that's ok or not.
1. Direct Memory access Controller
2. High Precision Event Timer
3. Numeric data Processor
4. Programmable interrupt controller properties
5. System Speaker
6. System Timer
Just ran Novabench and here are the results.
3/23/2015 12:08:47 AM
Microsoft Windows 7 Ultimate
AMD FX8350 EightCore @ 4333 MHz
Graphics Card: AMD Radeon R9 200 Series
16284 MB System RAM (Score: 213)
- RAM Speed: 7142 MB/s
CPU Tests (Score: 717)
- Floating Point Operations/Second: 266343912
- Integer Operations/Second: 650425328
- MD5 Hashes Generated/Second: 1023565
Graphics Tests (Score: 624)
- 3D Frames Per Second: 1684
Hardware Tests (Score: 38)
- Primary Partition Capacity: 466 GB
- Drive Write Speed: 103 MB/s
If you need more info just let me know.
I'm a noob so would need super detailed instructions and all that for anything you may need.
Also not sure if they sent me this new Mobo with the updated Bios, but have never updated Bios on previous one cause it looked pretty complicated. Would like to get this computer stable and juiced up to the max without any problems or having to check up on it every day. Really just stable.
Any help would be great. Thank you.
Yeah typos. I fixed them. Ok #'s look similar I guess. Should I even be using this software to see if my hardware's running at 100%?
Might be OK for you. I don't use it. I use my motherboard utility software regularly and HWInfo occasionally along with CPU-Z and MSI Afterburner.
Too many variables to get a good benchmark comparison. But I keep my eye on temps especially and then clocks, voltages, fan rpm. To know whether my PC is running as it should rather than how it compares to others.
