Build Advice Novice needs help with Video Edit Build
Mar 20, 2019
Hey guys,
I'm taking a break from my career to learn how to video edit and create content (and just have fun.)
I'm having difficulty in picking out computer parts that will allow me to have great flexibility for at least the next 3+ years with programs like Adobe Premiere CC and other similar programs.
It would be nice if I could run some modern games well too but this is less important to me.
I'm copy and pasting what I've picked out so far..But this is a few hundred more dollars than I'd like to spend, or at least, it's as much as I'll spend on the tower. So if there's somewhere I can save money that would be of great help!
Do I need to configure it a certain way to get the best USB ports with the motherboard and case for instance?
Please let me know what I'm picking out wrong, or if you have any suggestions, as I'm not technically knowledgeable.
Thank you!
CAS:CyberPowerPC AURON RGB Mid-Tower Gaming Case w/ Tempered Glass
Window + 6X Dual Light Loop 120mm RGB Fans & Controller [-18] (Black
Color)
CASUPGRADE:None
CC:None
CD:None
COOLANT:None
CPU:Intel® Core™ Processor i9-9900K 3.60GHZ 16MB Intel Smart Cache LGA1151
CS_FAN😀efault case fans
ENGRAVING:None
EVGA_POWER:None
FA_HDD:None
FAN:CyberpowerPC MasterLiquid Lite 120mm ARGB CPU Liquid Cooler with
Dual Chamber Pump & Copper Cold Plate (Single Standard 120MM Fan)
FLASHMEDIA:None
FREEBIE_VC1:Buy 2060 or 2070 and PICK ONE between BFV or Anthem or
Metro Exodus [+0]
HDD:1TB Intel® 660P SERIES PCIe NVMe M.2 SSD - Seq R/W: Up to
1800/1800 MB/s, Rnd R/W up to 150/220k [+38] (Single Drive)
HDD2:1TB WD Green Series SATA-III 6 Gb/s SSD - Seq R/W: Up to 540/465
MB/s, Rnd R/W up to 37/68k [+12] (Single Drive)
HEADSET:None
INSTRUCTION:None
IUSB:Built-in USB 2.0 Ports
KEYBOARD:CyberpowerPC Multimedia USB Gaming Keyboard
MEMORY:32GB (8GBx4) DDR4/3000MHz Dual Channel Memory (GEIL EVO POTENZA)
MICROPHONE:None
MONITOR:None
MOPAD:None
MOTHERBOARD:ASRock Z390 Phantom Gaming 4 -CB ATX w/ 802.11ac Wi-Fi,
ARGB, USB 3.1, 2 PCIe x16, 3 PCIe x1, 6 SATA3, 2 M.2 SATA/PCIe
MOUSE:CyberpowerPC Standard 4000 DPI with Weight System Optical Gaming Mouse
NETWORK:Onboard Gigabit LAN Network
OS:Windows 10 Home (64-bit Edition)
OVERCLOCK:No Overclocking
POWERSUPPLY:800 Watts - Standard 80 Plus Gold Certified Power Supply
PRO_WIRING:None
PROJECTOR:None
PROMOSALE1:Syber M1 RGB 6200 dpi Optical Gaming Mouse [+5]
PROMOSALE2:CYBERPOWERPC Skorpion K2 RGB Mechanical Gaming Keyboard [+5]
PROMOSALE3:ZALMAN ZM-HPS200 GAMING HEADSET [+5]
RUSH:Standard processing time: ship within 5 to 10 Business Days
SERVICE:3 Years FREE Service Plan (INCLUDES LABOR AND LIFETIME
TECHNICAL SUPPORT)
SLI_BRIDGE:None
SOUND:HIGH DEFINITION ON-BOARD 7.1 AUDIO
SPEAKERS:None
USBHD:None
USBX:None
VIDEO:GeForce® RTX 2070 8GB GDDR6 (Turing) [VR Ready] [-289] (Single Card)
VIVE_HEADSET:None
WARRANTY:STANDARD WARRANTY: 1 Year Parts WARRANTY
WNC:None
WTV:None
_PRICE🙁+2353)
Hey guys,
I'm copy and pasting what I've picked out so far..But this is a few hundred more dollars than I'd like to spend, or at least, it's as much as I'll spend on the tower (2200). So if there's somewhere I can save money that would be of great help!
Thank you!
Color)
CASUPGRADE:None
CC:None
CD:None
COOLANT:None
ENGRAVING:None
EVGA_POWER:None
FA_HDD:None
FLASHMEDIA:None
Metro Exodus [+0]
HEADSET:None
INSTRUCTION:None
MICROPHONE:None
MONITOR:None
MOPAD:None
PRO_WIRING:None
PROJECTOR:None
TECHNICAL SUPPORT)
SLI_BRIDGE:None
SPEAKERS:None
USBHD:None
USBX:None
VIVE_HEADSET:None
WNC:None
WTV:None
_PRICE🙁+2353)
