Question Novice question - - - CPU overheating ?
FozzyRFC
11
Hi all
I know my way round PCs a bit - I mean, I know what's what and can change the odd part here and there. But - I need help in doing it if it's much more than that.
I have a problem with my PC since I had it built by someone 2 years ago, and the work I have coming up means I really need to solve this now.
It runs okay for day to day stuff like email and admin stuff but when it comes to anything more, I've clearly got a problem and I don't know how to fix it.
The CPU temperature appears to be too high and it's overheating, causing a BSOD/shutdown with things such as MACHINE_CHECK_EXEMPTION or sometimes CLOCK_WATCHDOG_TIMEOUT which I think are both temperature related?
So.. I downloaded core temp and have it running.
Right now, my 6 cores are 54-65 degrees as I'm typing this with nothing much else running.
If I start for example Valorant, the fan(s)? go a bit louder whilst I can see the temps rising briefly 72-85 degrees, but only for a few seconds. I don't know if that's normal.
But
Here's my big problem. I need Adobe Premiere Pro and Adobe Media Encoder to be running for my work without all the crashing I'm getting.
In normal operation with Premiere running, if I open a project there's a brief rise in temperatures similar to seen with Valorant. Again, that might be normal? It's for a few seconds.
But...
Then I can do very little intensive stuff in Premiere itself. Any project with more than a couple of video layers and some moving stuff that requires rendering, crashes my PC most times. Occasionally it will crash whilst just preview playing the layers, and mostly it will crash whilst rendering.
On trying to render, the CPU temperatures rise dramatically. The fan(s?) are noisy and the temperatures are rocketing up thorough the 70s, 80s, some cores at 90+ and then once a core hits 100 it seems to crash (for safety, I assume)
So... Premiere is the big thing I can't do. If I research it, some people seem to suggest it's the software, but surely my PC should be able to cope with rendering stuff (even if it's slow to do it) without it nearly catching fire or blowing up?!
My issue is : I've no idea where to start with this, or how.....
If anyone out there feels like being patient with a non-expert, please can you step in with advice?
Thank you!
My PC specs are:
CPU: Intel Core i5-11600K (3.9 GHz / 4.9 GHz, 12M Cache) - April 2022
CPU cooler: Noctua NH-L9i, Premium Low-Profile CPU Cooler for Intel LGA115x
Motherboard: AUS TUF GAMING Z590 PLUS WIFI BIOS ver 1017 (assuming i've done the lookup correctly)
Ram: Corsair Vengeance LPX Black DDR4-RAM 3600 MHz 2x 16 GB
SSD/HDD: Samsung SSD 980 1TB
GPU: NVidia GeForce GTX 1060 3GB
PSU: unsure how to check, apologies April 2022
Chassis: NZXT H510, Compact ATX Mid-Tower PC Gaming Case
OS: Windows 11
Monitor: BenQ GL2706PQ
Problems have been present since Day 1, not just since parts have got older
If you need aany more details, just say. And please be gentle with me - if some of those parts are not great, I'm only going on what I was advised would work.
Maybe they're not fitted properly?
Cheers for now...... *runs for cover* :)
When posting a thread of troubleshooting nature, it's customary to include your full system's specs. Please list the specs to your build like so:
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
include the age of the PSU apart from it's make and model. BIOS version for your motherboard at this moment of time.
Noctua NH-L9i
https://ncc.noctua.at/coolers/NH-L9i-23/cpu/all?q=i5-11600K
I'm suspecting your case doesn't have proper ventilation/ariflow.
L9I is considered as unsuitable for a i5-11600K:
https://ncc.noctua.at/cpus/model/INTEL-Core-i5-11600K-1280
Your case can handle any of the better noctua coolers.
Look for one of the noctua NH-D15 variants.
If your case has two front intake fans, you should have no cpu cooling issues.
If you have not yet done so, update your motherboard to currency.
Updates often address stability issues.
The current bios is 1801:
https://www.asus.com/motherboards-c...esk_bios?model2Name=TUF-Gaming-Z590-PLUS-WIFI
CPU-Z will show you your current motherboard bios level.
Heat issues and throttling should not result in a crash.
The cpu should just lower performance until the issues is resolved.
I would uninstall the armoury crate app.
Reactions: Phaaze88
Have you opened it up to look at the CPU heat sink/fans? They may need a good dusting. Make sure your fans are working and spinning up to a proper RPM.
Also, if its been this way since day one, I would reapply thermal paste if you opt to replace the fan or heat sink.
Reactions: FozzyRFC
thanks.
I've airdusted.
I'm not sure how to:
know the fan is spinning at the proper RPM (it's definitely spinning)
and
how to reapply paste.
I can Google it or get it done
Thanks very much for all of that. I'll take a look over the weekend.
so for example this would be suitable and fit my case?
Noctua NH-D15, Premium CPU Cooler with 2x NF-A15 PWM 140mm Fans (Brown) https://amzn.eu/d/cpXh4WB
it looks like it comes with everything I need? So I'd remove old one and remove old thermal paste?
sorry for the novice questions. I don't want to get this wrong.
thanks.
thanks.
I've airdusted.
and
You might be able to see fan RPMs or a fan speed/temperature curve in the BIOS. You can use HWiNFO to monitor fans and more while you are in windows or an application.
Replacing the heat sink and installing a new one may require you to remove the motherboard from the case since the heatsink must be secured from the back of the motherboard.
There are plenty of videos on how to apply thermal paste, just make sure you clean the old one off with a little IPA and dry well before applying a small amount of the new one. Usually heatsinks come with a tube.
I think you can use the Peerless Assassin and save $50. Amazon
Thanks very much for that.
How do I confirm that the PA120SE is definitely compatible with my CPU and will fit in my case? Under product specs here on Amazon UK (I'm in UK) it doesn't specifically list 11600:
Thermalright Peerless Assassin 120 SE CPU Air Cooler, PA120 SE, 6 Heat Pipes Cpu cooler, Dual 120mm TL-C12C PWM Fan, Aluminium Heatsink Cover, AGHP Technology, for AMD AM4/AM5 Intel 1700/1150/1200 https://amzn.eu/d/iOiRqcg
The compatibilities listed are for socket type. Your motherboard and cpu are socket 1200. Sometimes memory stick in slot 1 can interfere with large sinks, but you can usually adjust the fan above it. Just something to understand with large coolers.
thanks.
Before recommending a NH-D15 variant I checked for compatibility.
Your case permits a cooler as high as 165mm.
The NH-D15 is a big cooler with 140mm fans that are exceptionally quiet:
It is 165mm tall. and can clear ram up to 32mm.
Unfortunately, your ram heat spreaders are 33.2mm high so some accommodation would be in order.
Low profile ram would be one solution.
Using a 120mm front fan would be another.
Moving the front fan up a notch is not an option, you only have 165mm.
I suggest the high compatibility version called the NH-D15S:
https://noctua.at/en/nh-d15s/specification
I use one with a i9-14900K.
Noctua makes the easiest and simplest mounting system ever.
It insures that the pressure on the cpu is correct.
Your case has an opening under the motherboard so in the event you want to remount later, the motherboard can stay in the case.
Run the cpu a bit to heat it up before trying to remove the old cooler. It softens up the paste which otherwise seems like glue. On/Off look at a web page then shut down should do it.
Disconnect from the wall before working on pc hardware.
Use alcohol, 70 proof is ok, 90 is better to clean off the old paste.
I use a paper coffee filter for cleaning; it insures that no residual lint is left on the surfaces.
Keep the cpu in the socket.
While the peerless assassin mentioned above is a good bargain cooler, it uses smaller/faster 120mm fans, it will not be as quiet as 140mm fans.
thank you
so the d15s will fit fine, but the PA will also be a good option, but noisier?
I'm not too concerned about noise level, as long as it's keeping the CPU temps down. It's also £60 cheaper. ..
HI all
So I've come back a week later to report that I've successfully installed a Pearless Assassin 120SE, whilst following a great YouTube guide. My temps are now way lower even in the most complex Premiere work, and no crashes at all in the 5 days since install.
Thanks to everyone on here who commented and helped: @geofelt @Gururu @Lutfij
I've learned a lot and solved my issue. Thank you.
