D dany.fdd69 Jul 5, 2018 19 0 20 Aug 3, 2018 #1 hey people, it is normal that my case nox pax blue edition has a red led on power button? shouldn´t be blue?
Solution alceryes Aug 3, 2018 Return the case or just ignore it. I mean you *could* swap out the LED if you find the right LED and are okay with doing that kind of work. But I would just return the case.
alceryes Splendid Jun 11, 2004 4,614 1,123 28,090 Aug 3, 2018 #2 It should be blue. Upvote 0 Downvote
alceryes Splendid Jun 11, 2004 4,614 1,123 28,090 Aug 3, 2018 Solution #4 Return the case or just ignore it. I mean you *could* swap out the LED if you find the right LED and are okay with doing that kind of work. But I would just return the case. Upvote 0 Downvote Solution
