[SOLVED] Nox Urano VX 650W 80 PLUS = Problems??
luis_estriga
40
Hello!
I read a couple of reviews about this power supply and some said it was bad since it didn't even had the specified wattage.
I'm building a gaming PC and i need a cheap but eficient power supply (80+ bronze). Would you recommend this one??
Thank you so much, i will pick you as a solution.
Have a great day!
EDIT: Just one more thing, should i get the 620W version or the 520w is enough? I want to save as much money as possible obviously.
https://www.pcdiga.com/fonte-seasonic-s12ii-520w-ss-520gb
Here's my build if you're wondering:
CPU: AMD - Ryzen 5 2600X 3.6 GHz 6-Core Processor (€211.44 @ Amazon Espana)
Motherboard: Asus - PRIME B450M-A Micro ATX AM4 Motherboard (Purchased For €0.00)
Memory: G.Skill - Aegis 8 GB (1 x 8 GB) DDR4-3000 Memory (€58.91 @ Alternate)
Storage: Crucial - BX500 240 GB 2.5" Solid State Drive (€40.94 @ PC Componentes)
Storage: Toshiba - P300 1 TB 3.5" 7200RPM Internal Hard Drive (€43.99 @ Amazon Espana)
Video Card: MSI - GeForce RTX 2060 6 GB VENTUS OC Video Card
Case: NOX - Hummer MC ATX Mid Tower Case (€46.70 @ Amazon Espana)
Power Supply: SeaSonic - S12II 520 W 80+ Bronze Certified ATX Power Supply
Wireless Network Adapter: TP-Link - TL-WN881ND PCI-Express x1 802.11b/g/n Wi-Fi Adapter (€13.29 @ Amazon Espana)
Total: €474.18
Generated by PCPartPicker 2019-02-02 16:16 CET+0100
