Hello
I have an NR200P arriving tomorrow and just wanted to double check your opinion on the fan positioning.
I'll be running a 240 AIO on the side with the GPU horizontally in the bottom of the case. I have 2 remaning fans that I had planned to put into the top as exhaust (getting the cpu heat out of the case asap) and leaving the GPU to independantly cool itself.
Do you think this is the best choice or should I use the 2 fans on the bottom of the case as intake?
Thanks
Thanks
