Archived from groups: microsoft.public.windowsnt.domain (More info?)
A long story, beginning 5/4/05 with the PDC doing an uninitialized reboot in
the a.m., which ultimately led to promoting the BDC to PDC (which did not
register with the old PDC since it could not be reached), then doing an ERD
on the old PDC, then using MS Article 196603 to fix C000000Df error on old
PDC after the ERD. That "fixed" that error, but now logon fails on the old
PDC, using any user name, including administrator, w/ msg to check user name
and password to be sure they're correct, etc. When the old PDC is off, the
newly promoted BDC Server Manager correctly IDs itself as the PDC and the old
PDC as the BDC. With the old PDC on, I cannot access Server Mgr. on the
newly promoted PDC, "Access denied". However, since I cannot log onto the
old PDC, I can't find out what's what on that machine. With the old PDC off,
WINS Manager on the newly promoted PDC (previous BDC) shows 15 mappings for
that IP address, including itself, the old PDC and the domain name, all
listed several times. (Since promoting the BDC to PDC, it now has the old
PDC's IP addy.) nbtstat -c shows one PC on the other subnet, a member server
and an XP machine on this subnet, all with <20> and a TTL of under 600 secs.
nbtstat -n on the new PDC shows: <NewPDC> 00 unique; (NewPDC> 20 unique;
<DomainName> 00 Group; <DomainName> 1c Group; <DomainName> 1b unique;
<NewPDC> 03 Unique; Administrator 03 Unique; <DomainName> 1e Group;
<DomainName> 1d Unique; MS Browse 01 Group. I've been told the only fix is to
delete the old PDC's name and do a fresh op sys installation on that machine,
installing it as the BDC, naming it the same/old name as it had, then
promoting it to PDC after everything is running okay. Needless to say, I
would really, REALLY like to avoid reinstalling the op sys but am at a total
loss of what to try to fix this and am hoping for help here....or at least
some other ideas of what to try before giving up and doing a fresh
installation. As I said, this all started on 5/4, and I've been working on
it since then, so if you need more info, please let me know. I probably have
it but don't know what is necessary to post and what isn't. THANK YOU SO
MUCH FOR ANY HELP!
MUCH FOR ANY HELP!
