NT 4 and Win2k dual boot problem
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: microsoft.public.windowsnt.setup (More info?)
On my NT4 machine I installed Win2k to a different partition -- no
trouble so far except for one thing that bothers me:
However, the system always defaults to Win2000 upon boot, even if I've
edited Boot.ini (on the first active partition, where the boot loader
resides)as follows:
[boot loader]
timeout=10
default=multi(0)disk(0)rdisk(0)partition(1)\WINNT4=
"Windows NT Workstation, Version 4.0"
[operating systems]
multi(0)disk(0)rdisk(1)partition(1)\WIN2000=
"Microsoft Windows 2000 Professional"
"Windows NT Workstation, Version 4.0 [VGA-Modus]" /basevideo /sos
C:\="PC-DOS"
Upon startup, I always get the following entries:
PC-DOS
Windows 2000 Professional (Standard)"
....and the system defaults to a non-existent (deleted) version of
Win2k...
This is the only instance of boot.ini on the whole system, so what did
I do wrong?
Not that it matters much, but it is a nuisance!
Helmut
All typos © My Knotty Fingers Ltd. Capacity Dept.
Helmut
Edit the default row to this:
The extra characters you keep in this row confuses Windows, so that it goes
back to a (hardcoded) multi(0)disk(0)rdisk(0)partition(1)\WINNT
To play it safe, before you edit too much of your boot.ini, format a floppy
from within Win2000, and copy the files boot.ini, ntdetect.com and ntldr
from the root of your C: to the floppy. This floppy will boot your system.
Edit boot.ini on your floppy until it works as it should, and then
overwrite C:\boot.ini with A:\boot.ini.
Best regards
Bjorn
Bjorn Landemoo - mvp2@landemoo.com - http://landemoo.com/
Microsoft MVP (Windows Server - File System)
>resides)as follows:
>[boot loader]
>timeout=10
>[operating systems]
>C:\="PC-DOS"
>PC-DOS
>Win2k...
>I do wrong?
>Helmut
> it goes back to a (hardcoded)
Thank you -- that was it!
I had copied the "NT4" line from the [Operating Systems] section to
the "default" line just to make sure not to add a typo....
Who would have thought that the "menu entry characters" would *not*
work while working in the [Operating Systems] section...
And yes, I do keep boot floppies for each installed OS on each machine
I run (BTW, what do the poor folks with the "hypermodern" machines
that come without a floppy drive do in case of emergencies?)
Thanks again
Helmut
