NTLDR and then KMODE_EXCEPTION_NOT_HANDLED error
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: microsoft.public.win2000.advanced_server (More info?)
My PC's description:
- P4, >700MB RAM
- HARD DRIVE: two 80GB drives using RAID 0 to single 160GB
- Dual boot: W2K Advance Server on C: partition and XP
Professional on D: partitions
PROBLEM:
Both OS were working fine until I updated SP for
Adv.Server, Adv.Server did NOT boot correctly and XP was
still bootable.
I decided to keep XP only, I accidently format C: (where
Adv.Server resided) then XP didnot start anymore and
gave "NTLDR is missing". I read some KBs on Microsoft and
thought that I already wiped out "boot.ini, ntldr,
ntdetect.com" on C: therefore it cannot detect XP. So I
decide to reinstall W2K Adv. Server again on C:
BUT after this install, it gave another problems:
1/ it won't show dual boot Adv. server and XP. But only
directly boot into Adv.Server but after boot directly to
Adv. Server it has "KMODE_EXCEPTION_NOT_HANDLED" error at
some point at "sis.sys" and it just hang right there.
2/ I used W2K Recovery Repair steps to see boot.ini file,
then I just saw
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINNT
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINNT="Windows 2000
Advance Server" /fastdetect
Then I added following line into [operating systems]:
multi(0)disk(0)rdisk(0)partition(2)\WINNT="Windows XP
Professional" /fastdetect
BUT it can't detect XP???
Please help multiple problems!!!!!
KMODE_EXCEPTION_NOT_HANDLED (0x1E)
This is a very common bug code. Usually the exception address pinpoints the
driver or function that caused the problem. Always note this address as well
as the link date of the driver or image that contains this address. A common
error is exception code 0x80000003. This error means a hard-coded breakpoint
or assertion was hit, but the system was booted with the /NODEBUG switch.
This problem should not occur very often. If it occurs repeatedly, make sure
a debugger is connected and the system is booted with the /DEBUG switch.
On non-Intel systems, if the address of the exception is 0XBFC0304, the bug
code is the result of a cache-parity error on the CPU. If the problem
reoccurs frequently, contact the hardware manufacturer.
Parameters:
1 - The exception code that was not handled
2 - The address at which the exception occurred
3 - Parameter 0 of the exception
4 - Parameter 1 of the exception
Possible Resolutions to Stop 0x0a, 0x01e and 0x50 Errors:
http://support.microsoft.com/default.aspx?scid=KB;EN-US;Q183169
Gathering Blue Screen Information After Memory Dump in Windows 2000 or
Windows NT:
http://support.microsoft.com/default.aspx?scid=KB;EN-US;Q192463
Crash Dump Analysis:
http://www.win2000mag.com/Articles/Index.cfm?ArticleID=16425
Windows NT Kernel Debugging Resources
http://www.win2000mag.com/Articles/Index.cfm?ArticleID=5132
Using Microsoft's x86 Kernel Debugger
http://www.win2000mag.com/Articles/Index.cfm?ArticleID=5131
Regards,
/Jimmy
Jimmy Andersson, Q Advice AB
Microsoft MVP - Directory Services
---------- www.qadvice.com ----------
"ht1234" <anonymous@discussions.microsoft.com> wrote in message
news:188a101c44b0c$d4b26b90$a401280a@phx.gbl...
> - P4, >700MB RAM
> PROBLEM:
> still bootable.
> then I just saw
> [boot loader]
> timeout=30
> [operating systems]
