Num Lock key does not come on by default anymore
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
Can anyone please tell me what I need to do to get my Num Lock on by default
at start up.
Many thanks
> default at start up.
http://www.winguides.com/registry/display.php/196/
<- Shenan ->
The information is provided "as is", it is suggested you research for
yourself before you take any advice - you are the one ultimately
responsible for your actions/problems/solutions. Know what you are
getting into before you jump in with both feet.
> at start up.
> Many thanks
WinXP, like its predecessors WinNT and Win2K, by design, ignores
the BIOS settings for the NumLock key as a standard security feature.
(I'm afraid I can't remember the "security" issue initially addressed.)
By default, the NumLock key is turned off as WinXP starts, and keeps
it off until someone logs in and initializes a user profile. WinXP will
remember the NumLock's last state, meaning that if you log out with the
NumLock on, it will automatically turn on the next time you log in; If
you log out with the NumLock off, it will be off the next time you log in.
If you need the NumLock on _before_ logging in, a registry edit can
be used to change WinXP's default behavior:
How to Set the NUM LOCK State at Logon in Windows XP
http://support.microsoft.com/default.aspx?scid=kb;en-us;314879
Bruce Chambers
Help us help you:
http://dts-l.org/goodpost.htm
http://www.catb.org/~esr/faqs/smart-questions.html
You can have peace. Or you can have freedom. Don't ever count on having
both at once. - RAH
