TheMajesticBurger Commendable May 2, 2017 140 0 1,680 May 11, 2017 #1 Does the amount of pins on a Gpu power connector affect performance? For Example, the Msi 1080 gaming z has 6+8 pins, while the Gigabyte G1 1080 has only 8 pins. Will the lack of pins affect performance, since I would like to overclock the card.
Solution Dark Lord of Tech May 11, 2017 Performance will still be very similar , although some of the higher power cards do have more OC ability.
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 May 11, 2017 Solution #2 Performance will still be very similar , although some of the higher power cards do have more OC ability. Upvote 0 Downvote Solution
TheMajesticBurger Commendable May 2, 2017 140 0 1,680 May 11, 2017 #3 Performance will still be very similar , although some of the higher power cards do have more OC ability. I would like to overclock the card to 2000MHz ( Higher if cold enough ). The card will be watercooled, too. Which one should I get? Upvote 0 Downvote
