Hi, I would like to seek answers on a number of things:
For now, that's all the question I have. Thanks in advance for your kind help.
■Is it true that to play a 3D movie on 3DTV, you don't need the Nvidia 3D Vision 2 kit, but just the 3DTV software which you can buy on Nvidia's website to enable 3D on 3DTVs?
■If I were to buy the 3D Vision 2 kit to use along with a compatible 3D monitor (e.g. Asus VG278H), will that Asus monitor be able to display 3D movies and 3D games from a PS3 too?
■Lastly, if I were to choose a 32" 3DTV, can I use that as my computer monitor too? I play FPS a lot and I heard that TVs are not suitable for use as a monitor due to the TV's image processors (e.g. Bravia engine and the likes?) processing the signals in order to churn out "better" quality imaging. However, if I can turn those features off (e.g. Samsung allows user to off its Wide Color Enhancer Plus feature under options, etc), will it then have less latency and thus able to use it for FPS gaming like computer monitors?
