NVIDIA Control panel issues
Heav
16
Hey boyzs,
Weird one:
- I have NVIDIA Geforce experience version 340.52.
- NVIDIA Control panel is saying to be both 340.52 and 7.8.760.0 versions
Ultimately my goal is to turn on GSync ... It just happen that the control panel doesn't have the option as you can see in the picture.
I run a double geforce 780 ti on the 144hz Asus screen via DVI cable.
What monitor do you have exactly? Is it one that actually supports G-Sync?
Besides the Asus ROG Swift PG278Q, which I don't believe has actually turned up at retail yet, the only other G-Sync compatible monitor I'm aware of is the Asus VG248QE modded with the G-Sync upgrade kit. With both of those monitors you have to use display port for G-Sync to function.
