In the Nvidiacontrolpanel is the new option: low latency mode
with 3 options: off, on, ultra.
off = allows gpu to prerender multiple pictures.
on = allows gpu to prerender one picture.
ultra = completly minimize prerendered frames.
So when option on allows one prerendered frame, how many prerendered frames does off allow?
What number are we talking about, 3, 30, 60, how do i find the value, or where did you find out?
My monitor is 2560x1440 165Hz
Dont know if i should use option off or on.
Also i dont know if i should set my max fps to 165 or 300.
My guess 300 will make it look smooth, while 165 equals to refreshrate.
