Ok I've honestly had enough of this crap. This is what happened:
My gtx 295 started to freeze and screw up, so i thought it was a problem with the card. I searched around, and saw it might be a driver problem. So i went into safe mode, deleted the drivers via driver sweeper, fixed registry errors with ccleaneer, rebooted into safe mode, and installed the latest drivers. It worked alright for a while, so i ran a stress test (OCCT) to check for errors. The first few seconds were ok, then i had about 15,000 errors (seriously 15k) and then crash. When i restarted everything that taxed the gpu in the least bit caused a crash. So i put in the 7500le i have now b/c i thought the gtx 295 was defective. I cleared and reinstalled drivers in the same manner. However, just by running windows aero, flickers appear every where, and if i dont switch to the basic theme quick enough I crash. So i cleaned and reinstalled again, and what do you know, i could run aero (still on the 7500le) however when i ran an occt stress test with error check to see if everythings alright, i had an immediate crash. I had to reboot to get back to using my pc.
What is wrong with the f****** drivers??? I can't stand this anymore, I don't know about my gtx 295, but I use that 7500le in an older pc and it works fine, so it has to be drivers.
I really need help with this quick.
