NVIDIA GeForce GTX 750Ti Graphics Card is compatible with my motherboard n specs!!
007paddy
8
I would say 310 watts is too low to safely run that graphics card.
No, I would not purchase that power supply. The power supply is the most important component in a computer. If it fails, there is a good chance it will also burn out other components in your computer. I would only recommend a quality power supply from manufacturers like Antec, Seasonic, FSP (Fortran Source), PC Power and Cooling, or Super Flower. A 400w to 550 watt power supply from any of these manufacturers would be sufficient.
If I had no other choice, a 500w to 550 watt power supply from EVGA, XFX, or Corsair would also suffice to power your system with that new card.
-Wolf sends
Hello!
It should be alright, The big yellow bar with a slot in it is the PCI/e slot so any graphics card will work.
as long as your PSU is 450W or more you should be alright but anything lower than 450W I would replace your PSU with a 500W PSU :)
thnx bruhh
SMPS VIP max power written 310w ...model no 400r plus
more detail about smps = http://www.akshatblog.com/vip-400r-vs-vip-400r-plus-vs-vip-400ex-smps-comparison/
should i buy this=https://www.flipkart.com/circle-apfc-500-watts-psu/p/itmeyw3nghz8g6zd?pid=PSUEYW3NHYRPGYUN&otracker=pp_reco_productRecommendation/similar_11
-Wolf sends
