nVidia GeForce4 Ti4200 V9280 TD Problems
mr_pollock
I am experiencing the following problem while using my computer, with this set-up:
3.06 GHz PENTIUM 4 WITH HYPER THREADING TECHNOLOGY
1024 MB PC 2700 CRUCIAL RAM
120 GB WESTERN DIGITAL HDD 7200RPM 2MB CACHE
ASUS GeForce4 Ti4200 128 MB V9280 TD
S.B. LIVE! SOUND BLASTER SOUND CARD
D-LINK GIGABIT ETHERNET NETWORKING CARD
52x24x52x LITE-ON CD-RW DRIVE
12X DVD-ROM
I am 99% positive that the problem is with the ASUS GeForce4 Ti4200 128 MB V9280 TD
While using the computer, under regular circumstances, such as internet browsing, the monitor will go blank. The monitor is not turning off, it is just losing the picture. I know that the problem is not my monitor, because I have tried the same computer with 3 different monitors. There is no given time to expect that the screen turn blank. It may happen within 15 minutes from turning the computer on, or may take 2 hours for the screen to go blank. The applications on the computer are still running, as when I have had music playing, it will still be playing after the screen goes blank.
I have tried different driver versions as well, and this has not helped either.
I had this problem running the 52.16 drivers. Upgraded to the 53.03 drivers and the problem went away.
I would suggest using the 40.72 drivers for that card. They are the most stable I've found for my 4200.
I aint signing nothing!!!
