Hi. I bought new graphic card, this one and after I put it into motherboard I can't switch on my computer.
My motherboard is GigaByte H61MA-D2V.
Is it compatible with the card, if it's not on this - http://www.pc-specs.com/gpu/Nvidia/700_Series/GeForce_GTX_750_Ti/883/Compatible_Motherboards list? (on the list is GigaByte H61MA-D3V only) .
Problem description:
When I try turn on computer it freezes on BIOS logo screen and beeps 3 times but with long pauses (so.. "AWARD BIOS 1 short beep" or "Memory parity check error. 3 short beep" - I don't know). After that there is black screen with "y" on the right side (pushing Enter = more "y"). Nothing more happens.
When I disable in the BIOS using Internal Graphics and make him to search graphic card on PCI slot - after save configuration it reboots continuously, screen is completely black.
Can you help me?
Sayansi
Can you help me?
Sayansi
