Nvidia HD Audio And Nvidia Virtual Audio Device?
Shaan5
577
I noticed these two in my Device Manager even though I chose not to Install the Nvidia Hd Audio Driver during my GPU Driver installation. Do I need them, my PC is connected to a monitor that does have built in speakers however I have basically never used them and I don't plan on it either as I use headphones instead, Would It be safe to disable these in my case?
Thanks
Safe to disable, but also safe to just leave the way it is.
However, this is for HDMI and DisplayPort audio (Separate in playback devices I think) so if you use monitor speakers it sounds like you're actually using it.
You can tell which solution you're using from "Playback Devices"
in Playback settings, my headset is set as my Default but I might just leave them on, *I might use my monitor speakers eventually thanks for the help
