Question Nvidia Shadowplay recording system sound too low
ahmedsalmanbajwa
31
So I have been Using Shadowplay for a while but recently encountered a problem.Well While recording the software only records by voice loudly while the system sounds(including my friend's voice) are extremely low
The game I want to record is Fortnite and Gmod but both have the same problem and i have tried turning system volume up,lowering my mic volume and turning of isntant replay.Other then that I use double track option for sound recording and tried fixing this by many YT videos which have so far not helped
I seriously Need help quick! thanks
Lutfij
You might want to see if uninstalling and reinstalling Shadowplay app changes the issue. Likewise, you should also try and make sure you're on the latest BIOS update for your motherboard, that you've uninstalled and reinstalled your audio drivers to rule out other factors.
