Question nvlddmkm issue
iMatty
1,239
144
11,390
So whenever I play apex the game keeps closing itself and when I check event viewer I get the error below:
The description for Event ID 153 from source nvlddmkm cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
\Device\00000123
Error occurred on GPUID: 100
The message resource is present but the message was not found in the message table
I don't know how to fix it and i would love to get some help!
My current setup:
CPU: i7 12700k
Motherboard: MSI PRO Z790-P WIFI
Ram: G.Skill Trident Z5 RGB 32gb
Graphics Card: MSI RTX 4070 Gaming X Trio
Power Supply: NZXT C1000 Gold
I have attached a screenshot of how my event viewer looks like while running the game up until it crashes and gives me the error above.
Imgur:
View: https://imgur.com/a/N17XksK
nvlddmkm
Try and use DDU to remove all GPU drivers(Intel, AMD and Nvidia) in Safe Mode, then manually install driver version 566.36 sourced from Nvidia's support site in an elevated command, i.e, Right click installer>Run as Administrator.
What BIOS version are you on for your motherboard?
nvlddmkm
Uh i dont remember which bios version am on currently but i did update a month or 2 ago.
Is there a place to check?
And for the driver i will DDU and install that version.
Another question is do i install the driver alone or with the nvidia app included?
According to dxdiag my bios version is A.F0
