Question nvlddmkm problem with RTX 2060 Super ?
MLLapan1
67
Hi.
I am getting error in Call Of Duty MW game, seems since new driver nvidia 516.59 is installed.
I did not get this error before on driver 511,79, to be honest I do not remember if I played game more than once on that old driver, but generaly i did not have this error.
My PC is like this:
z490-plus
i7 10700k
nvidia rtx 2060 super
Two SSDs samsung
So what would happen is that the game will freeze screen, pretty randomly without any logic behind it, and it will stay like that, I could hear Windows error sounds cling in the back but nothing appears, in event viewer I have this stuff...
Error below is usually repeated few times in event viewer that happened at the same exact time.
Code:
The description for Event ID 0 from source nvlddmkm cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
\Device\Video3
Error occurred on GPUID: 100
The message resource is present but the message was not found in the message table
Next...
Code:
Fault bucket LKD_0x141_Tdr:6_IMAGE_nvlddmkm.sys_Turing, type 0
Event Name: LiveKernelEvent
Response: Not available
Cab Id: 84c3208c-bfbb-486f-92ae-e00ac1bdfa46
Problem signature:
P1: 141
P2: ffffab03dcf65050
P3: fffff802a85804d0
P4: 0
P5: 6740
P6: 10_0_22000
P7: 0_0
P8: 256_1
P9:
P10:
\\?\C:\Windows\LiveKernelReports\WATCHDOG\WATCHDOG-20220728-0431.dmp
\\?\C:\Windows\SystemTemp\WER-1183538968-0.sysdata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.43d8e4b3-a2fa-4614-81e1-79e05cee45b1.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.d2d383ac-5ace-43ac-8c54-8a6522b3069c.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.84c73c20-a465-413c-a5d5-2a0ea42ca29b.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.8e7ed67e-efd5-4d30-bbfe-e8f0fc82da2e.tmp.txt
\\?\C:\Windows\SystemTemp\WER.c66aa3cb-920d-4b05-809a-ad8b6b6077a1.tmp.WERDataCollectionStatus.txt
These files may be available here:
\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\Kernel_141_a6ef9cdfd65ad6312d57316e875731c294c2ade_00000000_cab_3ca3bccf-c033-494d-9105-770d96ee0caf
Analysis symbol:
Rechecking for solution: 0
Report Id: 3ca3bccf-c033-494d-9105-770d96ee0caf
Report Status: 268435456
Hashed bucket:
Cab Guid: 0
And of course after those is typical "Display driver nvlddmkm stopped responding and has successfully recovered."
Computer is new completely, so I wonder is there a problem with these cards, anyone else had it and how to avoid it.
I am trying now hotfix 516.79 driver, but I have feeling it will do the same.
bFamous
Commendable
Aug 25, 2020
11
Have you found a fix for this yet, and is it happening when you try to run other games or the Heaven gpu benchmark (DirectX 11, High, Extreme, Disabled, Disabled, x8, 2560x1440 )?
I am having the same issues; have tried troubleshooting for about a week without any luck.
The older drivers I attempted to test were from last September, 472.12, without geforce experience installed using the clean DDU wipe in safe mode.
Tried that and the newest one, 516.94 . Both from the nvidia website.
