nVstrap help please... Enabling Vertex and Pixel units on ..
G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
How might I go about testing for any locked vertex or poixel units on a 6600
card? I'm using RivaTuner w/ nVstrap. Is that the best way to do it? Are
there other programs that will do the same thing?
Anyhow, I have a list of 32 addresses, 9 of which are enabled. Those enabled
are as follows:
bit field / bit mask Description
bit 00 - 0x00000001 Pixel unit 0
bit 01 - 0x00000002 Pixel unit 1
bit 08 - 0x00000100 Vertex unit 0
bit 09 - 0x00000200 Vertex unit 1
bit 10 - 0x00000400 Vertex unit 2
bit 16 - 0x00010000 N/A
bit 17 - 0x00020000 N/A
bit 18 - 0x00040000 N/A
bit 19 - 0x00080000 N/A
Is there any particdular method to see if there is anything to "unlock" or
is is systematically testing enabling each location and seeing if it works,
is faster, or locks up? Are there any articles online about this sort of
thing? Thanks for any advice or information anyone can offer.
Cory
G
Guest
Guest
On 6/25/2005 3:36 PM Cory Dunkle brightened our day with:
> Cory
In RivaTuner is anything marked "yes" under HW Masked? No? That would
make sense because there isn't anything on the 6600 to unlock.
"I don't feel tardy"
Steve ¤»Inglo«¤
www.inglostadt.com
G
Guest
Guest
"Inglo" <ioo@??.¿¿¿> wrote in message
news:Bolve.4038$Bx6.2477@newssvr13.news.prodigy.com...
6600
or
works,
> > Cory
Okay, that's what I wanted to know. I figured since IIRC the 6600 GT has
extra vertex and pixel units there could be something to enable, as there is
with the 6800 to 6800 GT/Ultra. Guess I won't worry about it and will just
continue to oveerclock. It's running stable at 370/581 now. Too much more on
the memory and it gives artifacts. Still going up on the GPU, so far it's
stable. Memory speed seems to be the primary limiting factor though, as far
as performance is concerned.
G
Guest
Guest
On Sun, 26 Jun 2005 02:11:04 -0400, "Cory Dunkle" <cdnews@comcast.net>
the 6600gts & ultras don't have extra pipelines over the vanilla. the
difference is the vram. vanilla has ddr, gt & ultra have ddr3.
dr ratt
i'd hate to advocate drugs, alcohol, insanity & violence to anyone but they've always worked for me.
G
Guest
Guest
Im running mine @ 380/610 (msi6600td), and have no probs. Running stuff like
Far Cry, D3, Halo, RTCW, UII, etc. No heat probs either, still running stock
cooler.
oldwolf
G
Guest
Guest
On Sun, 26 Jun 2005 20:23:06 +1000, "oldwolf"
>cooler.
i run my msi 6600 at 500/1000. the 77.30 driver optimised the speed to
550/1100 but i get artifacts in bf2 [not d3, hl2/cs, though] at those
speeds.
dr ratt
G
Guest
Guest
Sure there are. At least on the older version. It was a crippled GT.
6600
or
works,
> > Cory
> Steve ¤»Inglo«¤
> www.inglostadt.com
