The NZXT H440 Razer Edition has plenty of room for liquid cooling. It can fit up to a 360mm Radiator which is almost as big as you'll find. Hope this helps!
what about a custom loop down the line when I become good enough at it that I decide my main pc is worth the upgrade?
Well yes, you still need the radiator spacing for a custom loop but other than that there isn't much more you need to worry about unless you plan on getting a rather large reservoir, it'd definitely fit a majority of sizes.
