Question NZXT Aer P fans
Brian_278
236
Hey Guys,
I want to switch my fans to the same kind that are on my rad the NZXT AER P 120mm fans, but the screws that come with them are long as they are intended for rad use.
I have looked in various forums and bought about three different kinds that people have said worked in mounting them to the case (shorter and slightly wider)
But none of them work, anyone else try this (mounting these fans and using them as case fans) and if so, can you tell me exactly what screws you used.
Thanks.
