NZXT and Coolmaster Seidon compatibility
maikeru89
9
I was planning on buying a Cooler Master Seidon 240M for my 1st rig and i already have the NZXT Phantom full tower https://www.nzxt.com/product/detail/34-phantom.html
I know the top fans are 200mm but the Seidon is only 2x120mm fans. I would like to be able to use the larger fans the rig came with as well.
However, I have no idea if they will be able to fit together. I cant find any definitive answer. Please help me out before I commit to the Seidon.
Yeah, it looks that way. So then I guess my solution might have to be to go with the seidon 120 XL and mount it on the rear plate?
Ok so i actually found something. I can indeed mount a 240mm radiator into the phantom. it comes with 2 brackets taht can mount it with or without the fans 200mm fans attached. I should have seen it in the instructions... and it was too late and I already ordered the XL. but they have very similar efficiency benchmarks so I aint mad. Thanks for the help
