Part list:
CASE
NZXT S340 Elite Matte Black - Might rebuild in H500 later
CPU
INTEL Core I7 8700K 3.7/4.70GHz 6 Cores 12 Treads Coffee Lake
MB
NZXT N7 Z370 Matte Black - Intel Z370 - Intel LGA1151 socket - DDR4 RAM - ATX
AIO
NZXT Kraken X62 280MM
RAM
CORSAIR Vengeance 32GB (2X16) 3200MHz DDR4
GPU
ASUS GTX 1080TI Turbo 11Gb SSD
Samsung 970 EVO SSD M.2 2280 - 500GB
HDD
Seagate Ironwolf 3TB 3.5'' NAS HDD
POWER
Cooler Master GM 750W
Monitor
BenQ 2546 DyAc 24,5" 240Hz
Extra parts
0,5 meter SATA Cable
Tools
It is my first build, and quite an investment, so I want to make it perfect.
Looks are important, as you can see by my choices. I will play record, edit and maybe stream FPS games, and would like to be able to get as high frame rate and smoothness as possible while recording 60 FPS 1080p. I also settled on this 240Hz monitor because I'm gonna record 1080p for now anyway, and it seemed to have a slight edge in smoothness and price compared to a 1440p 144Hz.
Questions:
Answer to any of these questions are greatly appreciated!
CASE
CPU
MB
AIO
RAM
GPU
HDD
POWER
Monitor
Extra parts
Tools
Questions:
■ Dual Blower style fans seem too have better FPS, but will it matter? I like the look and back end exhaust of the Turbo.
■ I might want to do a small overclock if I feel the need for more performance. What is a safe OC range for this kind of build?
■ Do I have enough power?
■ Will I need to buy extra cables to have everything visual in black?
■ Lastly, I might switch out the case for the new H500 when it's out. Will I need do make any other changes for that case?
