NZXT Case Fan Layout + Corsair H100i
RoG Blackfox
47
Hello,
I was wondering what I did was a good idea? Well to begin I want maximum air flow for my CPU, and well... what I did I feel is either genius or not going to work. I've installed a Corsair H100i and have also put the standard 120mm fans on the intake side of the radiator, but what I did on my NZXT Switch 810 case was I installed two 140mm fans over the radiator, was this a good idea or will I get better airflow from a 140mm fan over a 120mm fan. Also the fans are connected to my case over the radiator, not directly connected to the radiator.
Question:
Should I stick with my current setup or Should I put AF120mm fans on my case instead?
the one from the case are outake one and the one on the radiator are intake from inside the case that will made a push -pull system for cooling the radiator do you have any other fan that push fresh air in the case and the same for outake .
Yeah, I have it set up in a push-pull config just with a larger pull than usual. I have a total of ten fans with 2 140mm pulling in from the fron, and 4 140mm pushing hot air out, one from the back and 3 on the top, two of which are above my H100i radiator. There are also, another 2 fans circulating air inside the case, and then there are 2 120mm fan pushing air into the radiator.
