NZXT Fan Hub and Water Cooling
Geoco240
38
I have 4 case fans connected to the fan hub on the NZXT H440, I am just looking for some advice on how to connect the hub to my motherboard.
I also have an X61 Kraken but I am not sure whether this needs to be connected straight to my motherboard or onto the fan hub as well.
The motherboard I have is a Z270-A Pro.
There is a 4-pin PWM cable coming off of the fan hub, as well as an extension cable and molex connector.
My suggestion would be connecting the pump to the 1 x 4-pin water pump fan connector, the two radiator fans to the 1 x 4-pin CPU fan connector, via splitter and the case fans to the 4 x 4-pin system fan connectors. No need for the hub, in my opinion.
