NZXT FN V2 or Fractal Design Silent R3 or Be Quiet! Pure Wings 2
WindowLickerAU
Commendable
Jul 4, 2016
84
Not 100% sure which one im going to get, probably the fractal fans. I was wondering which one is better? Has anyone had past experiences with either of them or all 3 and can share their opinion?
*I am getting 2x140mm at the font, 1x120mm at the back and 2x140mm on the top.
Thanks in advanced
After doing a little bit of research the two seem very similar. I mean there would be no real noticeable difference between the two performance wise if you put them in your case. Maybe someone else who's had more experience can shed some light but from what I can see is there is no real difference to pick between the two, they have very similar specifications. Just choose the one you would like, they will perform essentially the same.
