Question NZXT h200 Build Cooling Solution
Dec 12, 2019
Hi guys,
i will build a Aorus 2080 Super Waterforce with an AIO 2x120mm Fans (240mm Radiator) into my nzxt h200 case, which makes me block the front with the radiator of the graphics card.
Now i need a cooling solution for my 9700k. I have the option of placing a nzxt m22 single 120mm radiator aio on top. Or do you guys think i can even fit a push/pull config into it.
Or any other suggestions ?
thanks for the help.
Hi guys,
You can fit a Dark Rock slim in that case and if you have a good fan in the back (you’ll need to remove the top fan for the cooler) you’ll be fine. 120mm AIOs are useless for cooling really.
(I have the H200i)
