[SOLVED] NZXT H200i RGB Fans/Strip setup
Pisol
41
Hey guys, I'm having a hard time figuring out if the setup I'm planning is possible.
I just bought a NZXT H200i case, which comes with the "Smart Device" and the NZXT LED Strip.
I want to connect 2 rear output Adressable RGB fans, and the LED strip that came with the case.
The smart device has only one RGB channel, so I have to choose between the strip or "up to 5 RGB fans".
My motherboard is the Gigabyte Z390I Aorus Pro WIFI, which is RGB ready and has both 4 pin "normal" RGB and 3 pin "adressable" RGB connectors.
I simply don't know how to make everything work.
I don't have the fans yet, but the options are ID Cooling 120mm ARGB or Cooler Master MF120R ARGB, so I'm not sure if those ARGB fans are supported by the Smart Device or the CAM software either. I am also unsure if the NZXT LED stripe would work connected directly to my motherboard's RGB header.
Any ideas? Thanks in advance!
That much i can say that NZXT LED strip doesn't work with any other hardware than Smart Device or HUE+. Due to that, buy any RGB fans you like and connect them directly to your MoBo, while leaving LED strip for Smart Device.
