Hi guys just got finished building my pc yesterday :
Specs:
Sabertooth z97 mark 2
4790k @ 4.8ghz 1.24v with Cache ratio on 45. Cache voltage is 1.25v
H110 push pull intake
R9 290
NZXT H440
Ive got the H110 mounted at the front of the case intaking air with the stock fans then the radiator is placed and another set of sp140's pulling the air from the radiator into the case.
So Fans---->radiator--->fans---->mobo
Ive got an AF140 on the back as exhaust along side 2 more AF140's on the top as exhausts.
My idle temps with an ambient temp of around ,17c is 23 and my temps under Prime95 after around 5 mins are 83-85c. At stock the temps stay in the low 60's. Are these temps okay for this? Im using the stock Thermal paste corsair provide so i could chance that out for maybe a few degrees difference.
Does anyone own this case and know of any better cooling options. I could mount 3x 120mm at the top as exhausts instead of 2x140mm's
Any help would be appreciated thanks
Specs:
R9 290
NZXT H440
