I have a 780ti Matrix Platinum and I know that the card can fit in the case but what I want to know is that will I need to remove a drive cage or no? Because I have 4 hdd so I need to make use of the drive cages. Thanks.
It will fit 294mm cards with a drive in that slot. You can still use 4 drives the drives are not really mounted in a bay that removes mutable drives their single slot bays.
