Hello, I need some advice on my fan configuration for the best airflow. I currently have 5 fans installed, this diagram should help!
I have some concerns!
Firstly, should I switch the two top intake fans to exhaust as this would mean more hot air is being forced out as warm air rises!
Secondly with my x41 being on the top front side of the H440, this prevents two intake fans from being installed from the front, so should i switch the fan and the rad around ( would this allow me to fit two more fans)
Lastly, my one intake fan at the bottom front could be upgraded to a 140mm fan so should i invest in a very good fan (noctua, etc) and will this be enough intake cold air to keep my pc warm. With my current setup, idle cpu is 35c and gpu 50c but im looking to improve before I go to university. Any suggestions on fans and configuarion is really appreciated! Thanks
