NZXT H440 Fan Setup Help.
andreaszero
500
Hey, what's the best possible way to mount the fans on an H440? The cases houses 3x120 in the front, 1x120/140 in the back and on top I will mount my Corsair H100i with 2x120. I thought to use 3x120 in front, the 2x120 radiator in front and 1x120 at the back to even the fans so it's like this:
Intake: 3x120
Exhausting: 3x120
Should I do it like that or put a 1x140 for the case exhaust? Wouldn't more air being sucked out than getting in be negative air flow?
If possible, try something like this.
Mount 3X 120mm front fans as intake.
Set the Corsair H100i at the top and set those fans as exhaust.
top-back fan as exhaust.
