guys I just got my self an nzxt h440 v2 case. it has a fan hub there is cable labeled pwn cable coming out of the hub now I have an msi h170 gamimg m3 motherboard where do I plug the cable?
I pluged it into sys_fan3. it did not display on the bios it shoes 0 rpm on all fans except for the cpu fan wich Is pluged into cpu_ fan. all case fans are on with low noise now I tried to plug the pwn cable in to an other cpu fan hub all fans are still 0 on the bios but now they run at 100% when the pc is In use but when the load is down they die down in noise wich means that the board is doing its jub but why are the displayed as 0 rpm on the bios ?
Added breaks in your wall of text to help others understand what you're going through.
Please maintain proper punctuation and line spacing within your posts to help with delivery.
Lutfij
Lutfij
